Model overlapping
Hello everyone,
After I linked in everything in my project file, I realised maybe the model is overlapped yet no idea how to solve this. See the pic attached. Many appreciates if someone helps. Thanks!
6 Replies 6
What does that area look like in 3D?
Hi Barry,
Please see 3D pic attached below.
Thanks.
It is a bit hard to say without seeing the actual file.
When you look in plan what is at those locations?
It looks to me as if you may have short walls inside the main walls.
Not sure how to upload Archicad file, when I upload it give me a message 'invalid file extension'? I also think is another wall inside, how to make this disappear?
You will have to ZIP the file - but it may still be too big.
A file sharing site works well - just post the file link.
Can you show the garage area in plan with every thing selected.
I might be able to see what is happening from that.
David Maudlin
RJUNIMEL:
One possibility is that the interior Walls are on a different Layer than the exterior Walls, and these layers have different Intersection Group Number. You can make sure these numbers are the same for the two layers, or turn off the interior wall layer for exterior views.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
