Modeling Complex CW Structures ...
MuazOnline
Hi
any ideas if AC is able to model such complex structures ?
and what are the needed tools and how to do that ...
thanks
For example
You can model it in Rhino with Grasshopper and import as IFC
Best regards,
Ede
MuazOnline
you're right Ede, however i can do the same with Cinema 4D because it has a direct link for building complex object and the send it to ArchiCAD as a library part ...
but actually i was looking to one of ArchiCAD rivals (revit) and how you can build such forms and at the same time i got so optimistic using morph tool to create such forms, but to remain the leader in BIM and in the Architectural design industry I urge Graphisoft to build such a tool or integrate such forms into CW tool ...
