Modify which panel slides in a sliding door object
Hi All,
I would like to ask if anyone knows if there is a way to modify which panel slides in a sliding door object. The sliding door that I am using is a D3 sliding door 1 (AC15). This has 2 movable panels and they both stack behind 1 fixed panel. I would like 2 fixed panels, with the center panel being the sliding one. See the attached image.
Thanks
0 Replies 0
