Modifying bounding area of Worksheets
After creating a worksheet using the worksheet tool in the Model, how do I make a change to the bounding area that the worksheet covers? On V13 when the worksheet object is selected, the bounding area appears in green but doesnt seem to allow editing?
4 REPLIES 4
Erika Epstein
Zoom in on the worksheet as you want and then redefine the view and set the zoom to Current Zoom.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
David Maudlin
George:
If you are asking about changing the Worksheet area in the Plan view, then make sure that Marker Range (under On-Screen Display Options) is enabled. This needs to be enabled for the pet palette to appear to modify the Worksheet boundary. If this is not the case, then post a screen shot to clarify the issue.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erika Epstein
Or are you referring to the setting
Worksheet Selection Settings (ctrl/cmd+T)>Marker>Marker Geometry>Working Mode>Editable Polygon?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
David and Erica,
Thankyou. The setting I didnt have turned on was view>on screen options>marker range. Now I can redefine the area of the worksheet.
