worksheet view setting can not be modified when ! mark is there
For some reason the new worksheets I create have grayed out selections that can not be modified even when I try to "redefine with current window setting", it does not stick! please see attached.
thanks,
Joseph
3 REPLIES 3
Link
I'm not sure they can be set for Worksheets set as Source Markers. They can be applied to Independent worksheets. Do you need the worksheet marker or just the worksheet?
Link.
I am setting it as a source marker. Interesting enough I changed it to a link marker after creating the marker on the plan and the (see attached) setting sticks except structural "core" vs. the entire model but the selected portion of the floor plan does not show at all even with a rebuilt in the worksheet. I am completely lost, any help would be appreciated.
thanks in advance,
Joseph
Section/Elevation/Interior Elevation Viewpoints have 3 statuses: Auto-rebuild Model, Manual-rebuild Model and Drawing. These View Settings fields are enabled only if the status of Viewpoint is Auto-rebuild Model:
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/user-interface-refe...
Worksheets do not have such a status as their status is always "Drawing", since they are a Drawing generated based on the model (The Worksheet Settings Dialog does not even have a Status field like those other Viewpoint types.
