Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
Modifying multiple objects at once
OK. This is new. In the past when I wanted to modify multiple object at once I would select them all open Object Setting window and change the property that I wanted - say width.
Now in v18 I do the same but only one (last selected) is changing. Rest remain the same. Do I miss something here? I have hundreds of objects I have to modify (only so slightly). I can Select them alright, but modifications have to be done one by one. Help?
8 Replies 8
Are they all instances of the same object?
If so then they should all change.
If they are different objects then they will only change if it is exactly the same parameter among all the objects.
Those are all the same object.
They should all be changing then.
It is working for me in 18 with no troubles.
If you select just 2 or 3 objects is only one still changing?
Yes the same result. But it looks like it is object related.
It's the W Beam 18 an all Steel shapes from Metals library that are affected.
This is the closest object I can find to 'W beam 18' in the AUS version.
But I am still not having any trouble changing any of the parameters for multiple objects at once.
Does it make any difference if you select them all in plan or 3D?
I just tested it with the W Beam 18 in the USA library and had no issues either. Worked like it was supposed to.
Is it just one file or all files?
Jared Banks, AIA
Shoegnome Architects
Erich
Are any of the objects locked or on a locked layer? I recently had this happen but had selected one object on a locked layer and didn't notice. Once unlocked, everything worked as expected.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
To answer all questions:
1. It does not matter is I select them in plan or in 3D.
2. All files
3. Nothing is locked.
So I did a bi more digging and discovered the unique conditions of this problem and the solution. First of all I'm using steel beams objects serving as columns rather than columns objects. Reason is very simple. I need them slanted at the top and column objects don have that functionality at all (pity). so all of those beams are at the 90 degree angle.
This is happening only when the angle is exactly 90 degrees.
The work around then is:
1. Change the angle to whatever that is not 90
2. Change the Length (width actually ;D)
3. Change the angle back to 90 degrees.
Thank you all for your help.
