Modifying multiple objects at once
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-03-26
02:49 PM
- last edited on
2023-05-23
04:22 PM
by
Rubia Torres
Now in v18 I do the same but only one (last selected) is changing. Rest remain the same. Do I miss something here? I have hundreds of objects I have to modify (only so slightly). I can Select them alright, but modifications have to be done one by one. Help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-26 03:00 PM
If so then they should all change.
If they are different objects then they will only change if it is exactly the same parameter among all the objects.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-26 03:45 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-26 04:38 PM
It is working for me in 18 with no troubles.
If you select just 2 or 3 objects is only one still changing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-26 05:07 PM
It's the W Beam 18 an all Steel shapes from Metals library that are affected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-27 02:43 AM
But I am still not having any trouble changing any of the parameters for multiple objects at once.
Does it make any difference if you select them all in plan or 3D?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-27 04:38 AM
Is it just one file or all files?
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-27 04:53 AM
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-03-27 04:42 PM
1. It does not matter is I select them in plan or in 3D.
2. All files
3. Nothing is locked.
So I did a bi more digging and discovered the unique conditions of this problem and the solution. First of all I'm using steel beams objects serving as columns rather than columns objects. Reason is very simple. I need them slanted at the top and column objects don have that functionality at all (pity). so all of those beams are at the 90 degree angle.
This is happening only when the angle is exactly 90 degrees.
The work around then is:
1. Change the angle to whatever that is not 90
2. Change the Length (width actually ;D)
3. Change the angle back to 90 degrees.
Thank you all for your help.
