Molding in a Barel Vault ceiling
Hi! there are any library parts or any method to create a curved molding in a barrel vault?
Thanks
3 Replies 3
Erich
What type of molding are you looking to make? You could try using walls or beams to make the curved part in plan. Then convert to Morphs and rotate up into position.
GDL also offers a means to do this. That is what I ultimately used in response to a similar question I had a while ago (AC 11 or so): Plaster pattern on a barrel vaulted ceiling
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thanks, it will be kind of data molding in the molding schedule I will define the Profile.
But I will definaly give a look at your post.
Thanks
Erich
Since I didn't have the Morph tool at the time, it was a much more difficult proposition.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
