Chris Grantham
Vaulted Ceiling
I am trying to model a ceiling similar to the one pictured below. Basically trying to achieve a vaulted ceiling where the lines in the corners fade away as they emanate from the corner. Does anyone have any thoughts? Maybe the shell tool? Although I haven't been able to make it cooperate. Thanks in advance!
-Chris
16" MacBook Pro M1 Max
Mac OS 26
ArchiCAD 27 Build 6010
10 Replies 10
Erich
If you're on 15 it seems the shell tool should be able to do this. If you are on 12 as your signature suggests, then a combination of complex profiles and the roof tool would work.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Chris Grantham
Ooops yea I am on 15. Forgot to update profile.
Mac OS 26
Chris Grantham
Any ideas on how the shell tool will achieve this? To this point I have basically been making two detail extruded shells and SEOing them for mediocre and slightly messy results. Any other ideas using this tool?
Mac OS 26
Erich
I really am still on 12 so I will be no real help with the shell tool
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Djordje
Isn't there a vaulted ceiling object in the library?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
If you want to make it out of Shells you should create several Shell pieces and connect them to each other, that way unnecessary portions will be trimmed.
Check out these videos about the Shell Tool:
http://www.youtube.com/user/Archicad#p/c/1CA38C58B1DCFE58
Chris Grantham
@Djorde I am not sure that there is a vaulted ceiling object.
@lazy thanks, I was looking at these yesterday, but for some reason I cannot get several shells to resolve nicely.
Mac OS 26
Erich
It's hard to see exactly what is happening from the photo but can't you just use a complex profile wall? I know 15 provided a nice new toy for folks to use, but the older tech still works quite well.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Chris Grantham
thats not a bad idea...
Mac OS 26
