go
Chris Grantham
since ‎2007-08-08
a week ago
User Statistics
  • 236 Posts
  • 4 Solutions
  • 8 Likes given
  • 23 Likes received
User activity
Is anyone else getting this "Host Offline" error on the BIMcloud manager? It seems to come and go, but projects are taking forever to open and they are unusable when it comes to anything Teamwork related.
Has anyone else noticed that the CI site has been scrubbed of all things Cadimage/CITools and Archicad? You can get to the CITools website via some specific search engine queries, but nothing on the main site? I work in custom residential and the "good enough" of AC's cabine...
Is there a way to use GOs to remove the cover fill foreground but keep the surface image in elevations? I know you can manipulate it within the elevation settings but ideally I would like to use the same elevation tag for both color/rendered elevations and for more technical...
We have client that is unable to have multiple models on their tablet BIMx because they do not have a graphisoft ID. Ideally we would like for them to have two different versions of a model hence the need for multiple models downloaded to the tablet. If they were to go and c...
Has anyone found that the activity viewer within the BIMcloud manager does not work as expected at all? It seems to work at first glance, but then when you dig in and give it more criteria, it just returns garbage that is not in the formatted correctly at all, i.e. by user, ...
