Archicad 11 teamwork vs. Snow Leapord (ad nauseum)
Hello,
Our office is trying to upgrade all our stations to OSX 10.6 (currently 10.4) while still using Arch 11. Somewhat successful in that a solo plan (.pln) works just fine -- seemingly solid, but sharing/saving that into teamwork (.plp) is causing force quit situations, ala endless spinning ball upon completeing the project sharing setup.
Any ideas, folks?
Many thanks
Paul
Are you trying with the latest 11 hotfix and 10.6.8 on any machines that you are testing this with (e.g., not a mixed environment)?
Could it be any of the font or other Snow Leopard compatibility issues listed here:
http://www.archicadwiki.com/SnowLeopard
Do you get a crash report when you force-quit? If not, run Activity Monitor, select the 'not responding' archicad process and click the Sample Process button in the toolbar. Paste the first 20 or 30 lines of that here.
Karl
Hi Karl,
Thanks for the quick reply. I haven't tried your suggestions as of yet. I did try creating a new solo project and then sharing it as .plp --- success. So there's some sort of issue with existing teamwork projects on our server and the new operating system.
