2014-06-24
08:32 AM
- last edited on
2023-05-23
04:25 PM
by
Rubia Torres
2014-06-24 09:11 AM
Pro wrote:When you select the edge to edit and then click on the node or edge to start dragging it you should see the pet palette.
Hi guys, I've just started using the morph tool and I have done some tutorial on it. When using it I seem to have a problem where if I move a node in one corner of a morph object, it seems to create a diagonal line down the face of the shape. However I do not want to create this diagonal line, instead I want to move the whole entire edge along with the node. So how can I do that?
Pro wrote:This will be your editing plane (which can be helpful if left on).
Additionally how do I get rid of this blue "stuff" when ever I'm trying to edit something in 3D view?
Like in this picture the blue "stuff" is blocking the background so I cannot see what is going behind it and makes it really hard to edit in 3D view.
2014-06-24 09:19 AM
