Moving zones with 3d elements?
Is it possible to drag and copy zones with the 3d building model in 3d view?
Otherwise, I'm doing it in 2d and then arrange the other floors manually.
3 Replies 3
mRalin
You need to make the zones visible in 3d view by opening the View Menu - Elements in 3D View - Filter end Cut Elements in 3D...
Thank you for your help
may Allah be pleased with you and guide you to the straight path.
Do you know how to show zones in the section view with the attributes of the slab?
