2026-05-04
05:10 AM
- last edited on
2026-05-04
06:09 PM
by
Anyone out there does Stack models for quick feasibility studies?
I am sure there are plenty.
For something like below, the last thing you need, is to draw walls and slabs and roofs etc.
All you need is Volume and Space.
Why? Because at the early stage the model needs to be simple and nimble. Something easy to modify on the fly.
In order to do that, the less elements you have, the better.
Still, you would want to be able to get information out of the model, like:
Also, sometimes you would want to do some colour-coded 3Ds right?
The Zone tool would be the logical solution to do these tasks, but:
WHY??????
Just because of these fall-backs, I use slabs instead. That is not very intuitive, is it?
Another use case for Zones, where grouping and dimensioning would be great to have is at space planning.
I personally do not design walls to start with, I design spaces.
Walls are just drawn in once the space planning is settled.
Like in the below sketch phase, when things are a bit all over the place, but coming together for space planning.
Again, dimensioning and Grouping zones would be an easy answer, but no, I have to use fills or slabs instead and turn them into zones later...
Yes, I understand that my design methods may be a bit unorthodox, still I find it would benefit many users if Zones were not an afterthought (Annotation), but a Design Tool.
Just imagine this:
If Zones were not necessarily defined by bounding walls, but instead, the Walls were defined by the Zones, how much easier, better and more automatable the design process could be?
In the future I am thinking of a workflow where
Before we get to the above "Dream" stage though, we could just start with making it possible to Group and Dimension zones!
After all - just think about it - what is the difference between elements produced by the Zone Tool and the Slab Tool? Not much, right, so why could zones not be dimensioned and grouped?
2026-05-04
06:11 PM
- last edited on
2026-05-14
01:06 AM
by
Rita Gurjao
Design Intelligence initiative is being developed to do many of the things that you mention here:
https://www.graphisoft.com/en-hu/company/innovation/project-aurora/
On above webpage, you can join a waitlist for Design Intelligence initiative.
Design Intelligence initiative Product Roadmap page:
https://community.graphisoft.com/t5/Product-Roadmap/Project-Aurora/idi-p/682922
2026-05-05
03:48 PM
- last edited on
2026-05-14
01:07 AM
by
Rita Gurjao
Hi László,
Thanks for the response. I was aware of Design Intelligence initiative, but my wish to be able to group and dimension Zones still stands.
Why?
I am quite certain that making associative dimensions possible for Zones and lettin Zones to be Grouped would be a relatively easy thing to script for the next version of Archicad and it would solve the Feasibility stack model needs for most people. If in addition Openings could also work in Zones (Dreaming), that would be a cherry on top.
2026-05-05 05:10 PM - edited 2026-05-05 05:11 PM
Did you make wishes for these? That would be the first step of asking Graphisoft for them.
2026-05-05
05:45 PM
- last edited on
2026-05-14
01:07 AM
by
Rita Gurjao
I was told that Design Intelligence initiative is going to be available for 1 year...
It does seem like it is designed as a separate platform; but likely will have a plug-in or direct link of some kind.
2026-05-06
01:46 AM
- last edited on
2026-05-14
01:07 AM
by
Rita Gurjao
There is a presentation about Design Intelligence initiative that you can watch, it will give a good overview of what is planned.
Holger starts talking about it at around 9:00 in this video:
https://nxtaec.com/video/graphisoft-gabor-kovacs-palko-holger-kreienbrink/
(You will need to register for the site to watch it.)
2026-05-06 03:21 AM
wishes has become an obscure platform, at least in my most humble opinion, why cant he discuss it here? i think its a good idea and should be relatively easy to implement
2026-05-06 03:24 AM - edited 2026-05-06 03:25 AM
Glad to see they are still working on this, and its looking good! similar to what the digitalbluefoam guys have been doing, even if its just for the conceptual design stages. Ideally Archicad should be the bridge between these conceptual cubes and full-fledged projects. Hope they can pull it off
2026-05-06 10:22 AM
You guys are free to discuss it here, but in order for the Graphisoft Product Team to have any idea of how much a certain function is needed/wanted by users, the way to achieve that is to create a wish so people can vote on it, which will give some idea of how much support the wished functionality has from users.
3 weeks ago
Hi Karoly,
You are not alone 🙂 I'm also one of those architects that start out with zones to quickly do some feasibility studies. To group and have associative dimensions would be great! I will visit the wishlist page to check it out.
