Multiply in ArchiCAD 9.0
how do you multiply in ArchiCAD 9.0?
Oh, Ashley-of-the-many-questions: you would be quite surprised if you tried to use the online help or the manual. Amazing. The answer is right there! (And it is no different from 8.1)
Forgive my sarcasm, but you have asked so many questions like this over the past year that take all of 30 seconds of reading to find the answer... At some point, you must stand on your own two feet, yes?
I am sorry! you are right! After I post the question, I keep play around with the ArchiCAD 9.0 and I found the answer. It's a little bit different than 8.1, but not big different. :oops:
