Navigator Double Click
In the Navigator now if you double clicked a sheet or view, it opens the selection in a new Tab. The default in AC18 and prior was double-click just went to the sheet. Is there a way to change the double click default in the Navigator back to how it used to perform in AC18?
It seems like I either accept the new extra steps/lost efficiency or accept excessive tabs opening while navigating a 100+ sheet set.
(I really like how floor plans and 3D tabs can be changed just by right clicking on the Tab. )
2 REPLIES 2
You can choose in the Work Environment if views and layouts open in a new window (now a new TAB) or simply replace the existing one.
It is just the default is now different - used to be set to existing and is now set to new.
Thank you very much!!!!
