vfrontiers
AC19 Issues
I am sure there's a switch somewhere, but I've run into the following issues that I believe are "bugs" ...
#1
When editing a library part, the button the previously put scripts in a NEW WINDOW no longer does so... It actually overrides the main window with no buttons to navigate anywhere else in the part... So you have to go back to the WINDOW MENU and choose the part again to get back to the main window..
#2
In the same library part editor, it actually appears that the main part window has OVERRIDDEN the PLAN WINDOW... When I CLOSE the part window, it acts as if I've closed the project (and asks if I want to save changes, etc)...
Any fix? Anyone else experience this?
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
13 Replies 13
Erich
Duane,
I do not get either behavior. Opening the various scripts for a part in a new window opens a new tab with the desired script. The main part remains open in it's own tab and the plan window remains as well. I can close the individual script tabs separately. If I close the main part tab it will close all script tabs but the plan window remains unaffected.
This behavior seems to be as planned. I am not sure why you are seeing something different.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
vfrontiers
Great... it's just me...
BTW it's not limited to Library Parts...
Opening a WORKSHEET and closing... attempts to close the project as well..
Lucky me!
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
Even Layouts!
There must be a switch somewhere... ugh...
Granted, I can use APPLE-2 to get back to the Floor Plan... just one of those "Why did they change it" moments...
Duane
Visual Frontiers
AC3.14 - AC29
Erich
It might be time to try a reinstall or at least a new and reset
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
vfrontiers
Re Install... I just installed it...
Duane
Visual Frontiers
AC3.14 - AC29
vfrontiers
Here's another...
The object part DET_LUM...
Once I change it to CUSTOM SIZE... A & B are NOT visible, so I can't change the size...
Just me again?
Duane
Visual Frontiers
AC3.14 - AC29
Erich
That one looks like a minor error on GS's part. I took a quick look at the Det_Lum part and the A and B parameters are hidden in the parameter table. Looking through the code I would say this is a mistake since the custom size requires those parameters and there is no way to unhide them.
Report it. I'll send you my 2D lumber part if you want.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
vfrontiers
Was working fine... I'll just adjust my code here...
Where do I report bugs? Didn't there used to be a link in the HELP menu?
I got to Graphisoft US and there's now REPORT page there (that I can see)...
I can just email tech support, I suppose...
Duane
Visual Frontiers
AC3.14 - AC29
Stress Co_
There is the "Report a Bug" link near the top of this webpage...
Pretty weak, as it takes you to the "Where to Buy" page
(Like everyone should know to look up their local reseller to report).
Not to be too critical to G.S., but how's about a webpage specific to bug reports?
Marc Corney, Architect
Red Canoe Architecture, P. A.
