‎2010-05-14
04:17 AM
‎2023-05-23
02:56 PM
Rubia Torres
‎2010-05-14 06:15 AM
styliztik wrote:This means there are 10 units in the "block" of apartments
Hi, I'm taking a drafting class in my high school and ArchiCAD is one of the programs we use. we have ArchiCAD 12 (I don't know if that makes a difference or not). But anyways, we have to make a building with various things and I can't exactly remember how to do them.
it has to be a + or - 5% of a 500 sq ft 'single family apartment' with carport (one of 10 units[what does this mean?])
styliztik wrote:Use the geometry method shown as selected in the image below. Set your roof parameters (setout height - (wall height where it meets the roof), slope angle, thickness (nominal), materials etc.) then you just need to trace the outline of your walls, adjust any final settings and hit OK. Your roof planes will automatically join at hips / valleys.
Hip roof. I hear that's the defaut setting? how do I apply the roof?
styliztik wrote:This is the size of your framing timber. The second number refers to the thickness of the wall, which is what you set your wall thickness to in Archicad wall settings.
2x6 ext. stucco walls.
2x4 interior walls.
2x8 plumbing (wet) walls.
what does the "2x#" mean? and how do I change that?
styliztik wrote:Not sure what the 'merican definition of Studio is, but WIC is probably "Walk In Closet" (bigger than a cupboard)
Master bedroom (studio layout) with full bath and W.I.C.
what is studio layout and WIC?
‎2010-05-15 01:08 AM
