Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
New Hotfix for Archicad 10 - build 1010
A new Hotfix is available for Archicad 10 (build 1010). This Hotfix applies to all platforms, all language versions and both commercial and education licences.
You can download the patch with the 'Check for updates...' command in help menu. Please read the Release Notes carefully.
If you have not done so recently, please also check for the latest Archicad 10 library.
Gergely Kmethy
VP, Customer Success, Graphisoft
13 Replies 13
Laura Yanoviak
Yes! Thank You.
Any idea when we might have a "Changes since last update" for the AC10 USA Library Update? I don't dare update unless I know what I am dealing with...
jbArch
Any feedback yet on the 1010 patch? (Not ready to be a guinea pig myself)
I'm curious to know if it addresses the problem of zero K PDF files from the Publisher.... my biggest gripe about earlier builds.
JB
AC 21 (8002) & 22 USA
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
Aussie John
apply the GS label "object label 10" to an object in section and Archicad STILL crashes when updated in a layout.
This bug was assured to be fixed in this release, thats two releases now have passed. WHAT DO WE HAVE TO DO TO GET A SERIOUS BUG FIXED!!!!!
This occurs with the following standard labels
Object label 10
Roof label 10
Cheers John
[/size]
Link
It doesn't appear to, as discussed here.
Link.
jbArch
Interesting... yet the "bug fix list" mentions that they addressed a different problem with PDF publishing:
"46354 - PDF publish: Page Options button unnecessarily displayed when multiple layouts are published"
So if I understand it correctly, now we won't have to look at the unnecessary "page options" button before we publish our zero KB size PDF files? Incremental steps, I guess.
FYI the bug fix list is at:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes_10/BugFixList1010.html
JB
Rob
I agree mate, this is really insane...
::rk
Aussie John
Is an odd bug mind you. If you create a new label with no parameters or scripts it doesn't crash.
If you put comments at the beginning of the 2D script it stops the crash. (NOTE putting an end at the beginning doesnt stop the crash)
I have started a thread in the hope of debugging this object
http://archicad-talk.graphisoft.com/viewtopic.php?p=74261#74261
GS FEEL FREE TO CONTRIBUTE so we can apply the fix ourselves.
EDIT: I have isolated the bug to a line in the script but have no idea why it is causing the problem. (refer the link) Time for GS to takeover!!
Cheers John
[/size]
Aussie John
I cant see the PDF bug on my G4 laptop but Im not game to update the G5
EDIT: works on the G5 too
Cheers John
[/size]
Aussie John
http://archicad-talk.graphisoft.com/viewtopic.php?p=73831#73831
This bug NOT fixed (vectorial hatch on edges of roofs screwed)
Cheers John
[/size]
