Not so much a new user but...
Evening all,
I'm not a ArchiCAD user so much as a customer of an architec that has supplied me an ArchiCAD file and i need some help navigating it.
I've got the program installed on my Mac and i have the .pla file happily sitting on my desktop and when i open it apart from a library issue i see a top down view of the property.
I was also sent a 3D drawing of the property that I can only guess was made in the software but of course i'm not sure how to.
Can someone point me in the direction of some sort of idiots guide to get from a top down view ( see link 1 ) , to something that i can render up ( see link 2 ) , so give me a better view of my property.
Many thanks in advance.
http://www.flickr.com/photos/montpillard/2993034819/
http://www.flickr.com/photos/montpillard/2993043739/
2 Replies 2
Eduardo Rolon
If everything is ok with your installation, you might try the following shortcuts;
F3 to go to the 3D window
F2 to return
____
if you have the navigator open (usually placed on the right side of the screen) you can navigate using the buttons at the top
to;
1) Model view = model work environment and there is a 3D option in the list
2) View Sets = the views that are saved from the model with their specific settings, your rendered 3D view might be there with the specific settings
3) layout View = were you see the views from 2 placed on drawing sheets.
Double clicking on any item in those list will open the appropriate window.
HTH
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
David Maudlin
LCaller:
In addition to Eduardo's ideas, if you place a camera in the plan window, select that camera, then go to the 3d Window, then you will see the project from that camera's viewpoint. Go to Help > ArchiCAD Help, click on the search tab, enter "camera" in the search box, you will see help files for this tool. The help files here should be very useful to you.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
