Object Processing Limit?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-03-03
06:30 PM
- last edited on
2023-05-23
05:17 PM
by
Rubia Torres
Does anyone know if this is true, that there is some kind of object amount/polygon limit to what ArchiCAD can process in the 3D window? If not, does anyone know a way around this? I cannot upload the file due to privacy reasons.
Thanks in advance
Note: - The site is rather large, I would say about 300,000 SQ FT. There are plants, shrubs and flowers scattered all around the green areas.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-04 05:13 PM
It is also possible that there is some particular element (plant object or site mesh) that is hanging the process. You can check this by a binary search. Model half the site (as you have tried). If there is no problem model the other half. If the problem recurs keep cutting the remaining part in half until you zero in on the problem. If it does not occur in either half then maybe you do need more RAM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-06 06:25 PM
I tried the binary search method and it resulted in the tree objects that were slowing it down. I guess they have too many polygons or are way too complicated for mass use, which is weird because in close up views where you would only see 1 or 2 trees, they don't look that good. I guess its just a poor object. I will replace with other trees and see if that works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-06 06:35 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-06 07:11 PM
"I think that I shall never see
As many polygons as in a tree."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-07 05:02 PM
Chadwick wrote:Chadwick:
Two related issues:
1. When ArchiCAD generates a 3D view it goes through 2 steps: first it calculates the entire model (or whatever has been selected), then it actually creates the specified view in the 3D window. Even if there are trees not showing in a particular 3D view, they will be calculated during the first step.
2. So if any trees will not be shown in the particular view you are creating, then use the various selection methods (layers, marquee tool, arrow tool, Image>Elements to Show in 3D...) to eliminate them from the model generation.
Replacement of some or all of the trees, or changing some of their parameters may also work best.
HTH
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-07 05:35 PM
When combined with the secret translucent leaf material described on page 161 of my book, you can populate an entire city block with beautiful 3D trees and still have a reasonable rendering time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-07 10:56 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-08 12:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-08 08:38 PM
Let me plug ONYX TREE PRO as an excellent producer of fluffy, realistic trees.Dwight,
In what format do you import the objects from Onyx???
How large are the files??
How many of those trees can you realistically insert into the AC file?
It looks like a pretty good tree making software.
