Odd problem w/ elevations
Red
Has anyone ever had this problem. (see attached pic)
The log wall behind my handrail is bleeding through on the elevations. This is the first time I have ever had this problem?!?!?!
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
4 REPLIES 4
Very odd. I see it is only the lower 3 courses of the siding fill (or actual log?) that are bleeding. New one for me.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Ben Odonnell
Red,
Seems really strange.
Have you tried sending them backwards under your tools --->display order?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Red
After deleting the handrail and post and reinserting them here was the results.
As you can see the 3 lines on the left are now shorter by an 1/8 or so.
Maybe if I keep repeating this process they will eventually disappear!!
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
This may or may not shed any light.
I created a new elevation showing only half of the right side, and it generated correctly. So then I stretched the new elevation/section line to show the same width as the other, and now it is showing incorrectly as the previous elevation was.
Anyway I just thought I would share that.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
