Red
Odd problem w/ elevations
Has anyone ever had this problem. (see attached pic)
The log wall behind my handrail is bleeding through on the elevations. This is the first time I have ever had this problem?!?!?!
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
4 Replies 4
Very odd. I see it is only the lower 3 courses of the siding fill (or actual log?) that are bleeding. New one for me.
Karl
Ben Odonnell
Red,
Seems really strange.
Have you tried sending them backwards under your tools --->display order?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Red
After deleting the handrail and post and reinserting them here was the results.
As you can see the 3 lines on the left are now shorter by an 1/8 or so.
Maybe if I keep repeating this process they will eventually disappear!!
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
This may or may not shed any light.
I created a new elevation showing only half of the right side, and it generated correctly. So then I stretched the new elevation/section line to show the same width as the other, and now it is showing incorrectly as the previous elevation was.
Anyway I just thought I would share that.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
