rjwilden
Odd screen behaviour
Has any one else encountered this problem.
When moving from 3D to floor plan the screen divides the plan into two parts one frozen the other you can pan and zoom as normal. I can get back to default by going to full screen, but it is annoying.
Hopefully the screen shot is attached
Richard
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
13 Replies 13
I own the 3D Profiler. Mostly purchased it for producing Roof fascia for residential homes. It has proven too difficult to work with, so we have "gone-back" to just using AC roofs to model fascia.
So the answer is I do not actually use any Cadimage products.
rjwilden
This happens if you click to 2D within 0.5 sec after finishing orbiting. 3D model rebuild is suspended for 0.5 sec to avoid unnecessary rebuild in case you do continue orbiting. So, please do keep a 0.5 sec gap before you click to floorplan.
So its a BUG!, thanks for the timely answer Graphisoft. Could of saved me a lot of time trying to find a non existent solution.
Richard
Archicad V23:V24
No, Richard, its not a bug, its a FEATURE!
rjwilden
With spin like that you should become a politician.
Richard
Archicad V23:V24
