Offset does not work - neither from PET palette nor
Hi.
I'm trying to offset a rectangle I drew in ArchiCAD 18.
First of all, the PET Palette does not show me the Offset option, only the four (move, rotate, mirror, multiply).
Not like in this forum post: offset command
Also, if I go to edit and offset in the menu, ArchiCAD asks me to pick a reference point and regardless of what I choose, nothing happens.
The rectangle is only offset on three sides, not all around?
Eirik
I think I found the answer.
I had drawn the rectangle with the line tool, so it was only a grouped collection of lines.
When I drew the rectangle as a Polyline, everything worked as should.
Eirik
Stress Co_
Eirik:
It will work with grouped lines, but you must
"Suspend Groups"
Edit> Grouping> Suspend Groups
Marc Corney, Architect
Red Canoe Architecture, P. A.
