Open with current view settings
sknsnw9
When opening the section views from the plan or details from the section, it will open with current view settings of the floor plan.  Is there a way to change that setting to actually open with the correct setting those sections already have implemented? Or is it best practice to always open them from the View Map?
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
10 REPLIES 10
Yes, I think that feature is pretty cool.  The more I'm using Archicad, the better I'm starting to like and understand the program compared to Revit.  I think I find it a bit easier to work with so far.  I really like the ability to temporarily change the settings without it being permanent and not needing to remember to change it back once you're done with it.
