Opening tool - custom shape
CarlM
I have a custom profile that I use for creating holes in CLT-panels. I would like to use the opening tool instead to create these holes rather than a beam with a custom profile.
In plan view and on a slab I can paste the custom shape and use the magic wand with opening tool to acheive this, but I cannot save the shape as afavorite and thus not use it on walls.
I have tried a work around and use "Connect/Create opening from selection" however the shape of the custom profile is translated in to the nearest circular or rectangular opening (in this case a rectangle).
Has anyone been able to save a custom shape for the opening tool so that it can be used on walls?
Thanks!
undefinedundefinedundefined
AC 27 SWE, 64-bit
Windows 10 PRO
HP ZBook Fury 16 G9 Mobile Workstation, i9-12950HX, Nvidia RTX A4500, 64GB ram
2 ACCEPTED SOLUTIONS
Hello @CarlM ,
1 - Model a slab
2 - Name its ID "wallhole" (without "")
3 - Select this slab
4 - File/Objets and libraries/Save the selection as/Window
5 - Use you own wall hole
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
DGSketcher
Legend
@CarlM Wallhole only ever creates a rectangular opening. Expanding on @Christophe Fortineau suggestion, you need to create the wallhole but add an infill that forms the hole profile.
See if these two links help...
https://community.graphisoft.com/t5/Design-articles/How-to-create-Custom-Window/ta-p/303432
https://helpcenter.graphisoft.com/graphisoft-archives/25570/
4 REPLIES 4
Hello @CarlM ,
1 - Model a slab
Christophe - FRANCE
Thanks for your quick reply Christophe!
It is a good suggestion that I had forgotten existed!
However the window shape is for some reason still translated to a rectangular opening...
undefined
AC 27 SWE, 64-bit
Windows 10 PRO
DGSketcher
Legend
DGSketcher - thank you for clarifying Christophe's suggestion!
I had over looked the importance of "WALLHOLE" as ID - makes all the difference!
@DGSketcher & @Christophe Fortineau - thank you both for excellent guidence and clarifications! Problem solved!!
AC 27 SWE, 64-bit
Windows 10 PRO
