PARKING PLACE 24 Dimensional Issues
Jeff Galbraith
Anyone else have issues with the Parking Place 24 object?  There seems to be a bug with it.  a 26 foot wide object should be enough for one regular 9 foot wide stall plus one ADA stall (9 foot wide + 8 foot aisle).  However with the object you have to stretch it out almost another foot get it to register.  And you can see from the screenshot below that the hotspot associated with the edge of the parking stalls are not aligned with the stripes in 2 locations.
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
1 REPLY 1
Marc H
It is a nice tool, but it does not appear as 'road-tested' 😉 as some objects.  I use it for conceptual planning and my workaround is to use it in single stall type sections, and not use the combination feature.  That also helps me make design edits a bit easier.
(It appears to move off dimension with different stall stripe widths. )
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
