PDF and fonts
Hi, I'm trying to output a file as PDF. I use an architectural font on my drawings. When I save as PDF the drawing is devoid of fonts. I don't see any settings where I can save my fonts with the drawing. Can someone tell me what I'm missing? Thanks.
It works with another fonts? If yes than I would try an another ''PDF printing'' software. I used before PDF Factory but now mostly Cute PDF Writer.
Thomas Holm
You haven't put your system profile in your signature, so any answer must be a guess. If you Publish, not Print, your PDFs from Archicad, that should work if the font is available in your system.
