Parameter exclusion in Favorite Preferences
I noticed that since AC17 the parameter exclusion in the favorite preferences is not stored in de file itself but is global.
Up to AC16 what you saved in the favorite preferences was only for the file you were working on. This is something that I found also on a website.
http://www.onland.info/archives/archicad/index.php?page=all
Athough an old entry it is true up to AC16.
In version 17 if I change something on the favorite preferences it stays that way for other files too. It's a global setting now.
Am I missing something? Is there a switch that I should set on/off? Or did Graphisoft changed this to be part of the work environment?
[Just in case I have updated to hotfix 6004.]
0 Replies 0
