Bob Moore
Plotting AC 12 in Leopard
I have just installed Leopard and AC 12 won't recognize my plotter. I plot to an Oce/TDS 320 through an IP address. In Tiger we had to use the HP 650C drivers in AC, but it worked. any one else have a problem with Leopard changing settings?
I did a search and tried the solution but it wasn't appliable
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
4 Replies 4
Aaron Bourgoin
Does this printer driver work?
http://global.oce.com/products/tds320/Downloads.aspx
are you set up to plot from AC to this device, or can you set the OCE up as a "printer" and 'print' to it.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.34 Mac
MacOS Tahoe 26.5.2
Bob Moore
I Plot to the device, I'll download and try the drivers.
Thanks
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Rick Thompson
I plot to an Oce 9300, and had no changes to make. I plot to an HP JetDirect box connected to the Oce. I had no driver issues. Can you ping it? I am even going via Airport. I do plot through Plotflow, which is far easier than direct from the Plot panel, at least hat has been an issue for me. In case you don't.. plot to a spool folder, which plotflow reads.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Bob Moore
Yes I can ping the plotter. I have never used plot flow.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
