Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Non-uniform Composites...
Hi all!
Just wondering... is there a way of specifying a wall composite that isn't uniform across the perimeter of the wall? (ie. wall studs)
Matts
2 REPLIES 2
This is only possible with a Trapezoid Wall where the Core of the Composite will change its thickness and all other skins will be of constant thickness.
But it is not possible for the type of thing you are referring to.
I think CadImage has Add-Ons for such purposes:
http://www.cadimagetools.com/tools.aspx?id=4
Thanks Laszlo That's what I needed to know. Will look into CadImage.
Matts
