Point clouds still slow
Denissss
I was wondering if someone else is using point clouds and how are your experience with it?
Last time I was able to use point clouds decently in AC26. Then in AC27 point clouds were broken and worked very slow. Tech support promised that it is a known issue and in AC28 it would be fixed. But for me point clouds are still extremely slow. Just have to work with one and it just goes so slow that it is unusable. Every move just keeps buffering for about 20 seconds. In 3D its even worse.
I have a .e57 file that is 3.6gb and it is just a small private home. Point cloud has some surrounding in it too, but nothing too crazy.
Is it still broken or there is something that needs to be done for it to work properly?
Operating system used: Windows 5000
Archicad 28 Solo, Windows 11 Pro, Dell Precision 7560 Laptop (64GB RAM, i7-11850H, RTX A4000), Dual 27-inch Dell Monitors (2560x1440).
10 REPLIES 10
Thanks for the feedback. Please report this issue to your local reseller so they can escalate it to GS HQ.
Setup info provided by author
