Possible to make a situation plan?
i just made a building and set it on a terrain (mesh). now the problem is i use some terraces separated from the building wich i do not want them to be seen in all the stories, and i want to make a situation plan to include all the stuff that building has. i want to see the roof and the building and all the terraces and roads i have in the project. is there any way to do this except making another story? (because this requires for me to set each and every roof / terrace / road / mesh to be visible in that story.
1 REPLY 1
i think you should be using the View map for this one.
