Printing to PDF freezs Plotmaker
In recent weeks I have been unable to print using Amyuni PDF converter.
It doesn't happen all the time but on some files it will freeze plotmaker.
I have tried it with my template file and it print OK, so that suggests to me that there is something I have imported that is causing this. I import my drawings as PLN's.
Has any one ever had a similar problem.
Richard
Djordje
8.1? Which OS?
Memory? Disk space? Access rights? Saving the PDF to local disk or network?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Quote Memory? Disk space? Access rights? Saving the PDF to local disk or network
Windows XP pro
8.10 R2 NZE 2284
System Memory Not sure which bit is important I'm afraid I don't know much about whats happening in the background.
These numbers below were with AC and PM running
Total physical memory 1 GB
Free physical memory 683 MB
Total virtual memory 2.66 GB
Free virtual memory 1.81 GB
I have 2.5 GB in my C drive where AC resides
8.3 GB in my D drive which is where my projects are
1024 Ram
Access rights? I am the only one using this computer and it is not networked
I tried removing some of the drawings from my PM layout and had some success with removing the elevations, but this was not consistent as latter on it froze again.
Thanks Richard
I had some issues if the fills "display and output" option (in display setting) was set to bit map versus "keep original settings". It would be nice if display and output were separate for this setting. I change it if I have imported drawings that are heavily laden with vectorial fills such that I can navigate through plotmaker in a reasonable amount of time.
