Problem! Trimming the walls above the roof.
Hello!
I am from Russia. Do not know very well English.
Please tell me.
Remains end wall when I cut it off. Look at the screenshot.
How can I fix it?
David Maudlin
KoDA86:
Two Options:
1. The Roof's Building Material Intersection Priority must be stronger than the Wall's.
2. Use Solid Element Operation > Subtraction with upward extrusion to remove the upper part of the Wall.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you very much! Everything turned out! You helped me a lot.
