Project North not relating to the shadow diagram
Im having trouble with rotation my north to reflect the true sun. As a standard north is always up the page but to see my whole plan I have rotated it to fit an A3 page.
See image below. If I change Project North the shadows stays the same.
why is this not related?
How can I change the north to reflect the true shadows?
6 REPLIES 6
It seems to be a 3D document which is related to a 2D plan view
Try to create another 3D document view after changing your north to check it
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Christophe wrote:
Does this mean I need to make a new sun study? I was hoping I could change this without having to redo any views since this is all office templates.
Is there no way of updating these 2d views?
Luiz Braga
I am experiencing exactly the same issue you had years ago. Would you happen to know the answer by now? Thanks.
@GRAPHISOFT
Any solution to this question. We are using AC25 and the same issue is happening.
Came across this whilst testing out our new office template in AC26 and running into the same issue. i.e. Any premade shadow diagrams (3d Docs) will have their north  orientated to the direction of project north was when it was created.
We found that we could 'reset' each 3D document by going into into 3D Document Settings > 3D Projection. And without changing anything, OK out of both. This will get the view to recheck and re-render the shadows.
Annoying, but beats completely remaking the 3D docs. Also applies if, for whatever reason, Project north needs to be modified.
louis gadd
this worked for me
