Dontknow
Project info
When you open a project you can see a window with project information for a short time.
Can this info be found in ArchiCad after opening the project?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
You can see this info if you go to the Open File dialogue, set for a 'Detailed' view and customise the fields.
You can also see this in your Windows Explorer.
Or do you want to retrieve and use this info?
I think you would need an add-on to get that.
Dontknow
De project information from ArchiCad and de file details from Windows Explorer are not the same.
ArchiCAD 25.
