‎2010-11-03 03:44 PM
‎2010-11-03 04:16 PM
‎2010-11-03 09:45 PM
‎2010-11-03 10:12 PM
‎2010-11-03 11:09 PM
‎2010-11-04 03:29 AM
‎2010-11-04 02:28 PM
Barry wrote:I have always agreed with this and that is why in the Past I had never had a template with Cloned folders.
If a view is missing or has the wrong settings then there is no point in having it there in the first place.
Barry wrote:I now am using many of the Cloned Folders in my View Map. I often Place a "N/A" before the view name on the views that are not used.
A good template is essential to already have the necessary views in place and automate the creation of new views with "Cloned" folders.
‎2010-11-05 09:11 AM
‎2013-02-25 05:43 PM
Barry wrote:Barry:
When set up correctly the View Map is fantastic as you can have as many or as few views as you need.
Organising it into a logical structure with the use of folders is essential as you can expand or hide these folders as necessary.
‎2013-02-26 02:11 AM
Stress wrote:That's good because I don't use teamwork.Barry wrote:Barry:
Have you noticed any problems with Teamwork projects not "remembering" whether or not folders are expanded/hidden?
"Save" works for solo projects... but not Teamwork.
EDIT:
Ah, never mind, found it
HERE
