Projection setting default negative on Z
0046247
Where do I change the Z-axis default value? As of now it's negative which is a bit annoying since I have to change it on every Project.
5 REPLIES 5
Erwin Edel
You can pick a preset from that top right button that now says 'custom axonometry'. That should reset all the axis to a proper scale and orientation.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
0046247
Thanks! #obviouslyineedglasses
0046247
But I still get the negative value next time i start a Project so I'm clearly doing something wrong here 😕
Erwin Edel
Change your template. The settings are probably saved in that.
www.leloup.nl
0046247
That might be the thing. Checking that out.
