Quick Way To Remove Window/Door Opening Lines To Multiple
I have quite a large model over 3 levels. With that comes quite a lot of windows. I made the mistake of leaving opening direction lines on.
How can I select just the windows and change this setting?
I don't want to have to select every single window. That would take hours.
Thanks
Actually, same applies with the doors also. They also have the ugly opening lines on, whilst in 3d.
Thanks
2 Replies 2
vistasp
You can adjust your model view options to control these lines. In v.13, it is global but from 14 onwards, the individual doors/windows have overrides for greater control.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
David Maudlin
obeythevuvuzela:
If you do need to select all the windows, go to the 3D Window, select the Window Tool, then Edit > Select All Windows (Command - A on the Mac). Then the parameter can be changed for all windows at once.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
