Renaming Cameras in a flythrough path
I had a situation in the training room where one of the students created a flythrough path and then afterwards wanted to add cameras within the path to create a smoother, more thorough fly through.
Is there a way to rename your cameras so that you control the flythrough path?
For example, if I have 5 cameras and add a sixth in between cameras 2 and 3, then camera 6 will be the last view in the flythrough path.
Chees for any advice.
3 Replies 3
Select an existing camera in the middle of your path and then drag a copy.
Unfortunately there is no way to rename the cameras in the Navigator. You can rename views that are based on the cameras in the View Map but this doesn't help with your problem.
Thankyou for the responses guys...
I wonder whether in 5 years time creating flythroughs in AC will be a thing of the past? VBE to me seems super.!
