Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
!Restored: how can i align and distribute like the following situation?
if i place chairs in the floor plan randomly, it is easy to align them linearly, but how can i align and distribute them in an arc and face to the same centre?
2 REPLIES 2
Dwight
Place a chair facing where you want the center of the array to be.
select the chair
Multiply the chair using the criterion "rotate"
Click the the center of the array and drag in a circle. The chair copies will follow. You can also constrain the copies to make a complete circle without actually dragging around - the default.
You will notice that there is a "distribute -1" option. Use that to avoid making an overlapping extra chair.
Get some training. page 136 usa reference guide.
Dwight Atkinson
done!!
thx!!
