Roof Fascia clean up
i noticed that when I'm using the Geometry Method: Polygonal and I've selected the Perpendicular roof edge. The fascias do not clean up. If I use the vertical edge it works fine. Is there a work around for this or am I missing something. See attachment
14 Replies 14
What's shown in your screenshot usually indicates some other modeling error - roofs not properly joined, fascia angles different, etc...
Use the pet palette in edge offset mode to pull the hip ridge back for each of the two roof planes.
Verify that each plane is set to the desired edge condition.
Select one roof and control (cmd Mac) click on the hip edge of the the other roof. Reverse the process to complete the healing / join. Should be fine now.
Karl
Hi Karl,
Thanks for your response. The snap shot I sent was of a simple square with a hip roof. All four corners have the exact same characteristics. I zoomed in to each corner and they all match perfectly. The pitch 6:12 with the degree, minutes and seconds exactly the same. All four roof plans are of the same thickness and elevation. If there was a modeling error wouldn't it effect the fascias for a vertical edge as well which shows correctly when set to that edge configuration???
You'd think it would clean itself up, but what you show is what often happens when changing the roof edge angle after the first clean-up, in versions (such as yours) before the new roof tool that arrived in 15.
Karl
Thanks for the update. I guess it's live with it or update.
No need to live with it... it cleans up easily in your version ... you just have to either model it right the first time, or do the steps I gave for re-cleaning the roofs. Takes 10 seconds per corner.
If I wasn't clear about how to fix it, please ask again - and maybe attach an MOD file of your roof and one of us will clean it up for you.
Karl
Erika Epstein
Just reset the roof edge Angle. If it is set to the angle you want but shows incorrectly, then set it to another angle choice and then put it back to the one you want.
Toggling settings like this often rights Archicad.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Tried Erika's suggustion of changing eave angle and then change back with no success. I'm trying to send a .mod file and I'm not having much success with that either.
You need to zip the mod file to attach it... should contain only your roofs to keep the size small... select the roofs, save-selection-as...
K
here's the roofs in zip format. Hope you can do something with them
Thanks
