2007-05-14
01:26 PM
- last edited on
2023-05-23
03:18 PM
by
Rubia Torres
2007-06-22 03:38 AM
2007-06-22 02:12 PM
mac_mosquitocreek wrote:You can copy and paste from floor to floor. The height of the roof is set relative to the floor level, so will need to lower the roof after the paste, use the "Relative to Project Zero" to keep the same height you had on the first floor.
thanks...if i understand, then i will have to redraw the first floor roof on the second story using the ghost wall below as pivot line..? -i'm pretty sure i drew it on the first floor plan..
-maybe i can cut and paste..? will this fix it ?
mac_mosquitocreek wrote:Roofs, slabs and objects have an option to display on more than their home story. To hide the roof, put it on a layer that can be hidden with layer combinations.
what i am after is to see the roof below if i am looking at the second floor plan. and not see it at all on the first floor plan.or be able to turn it off altogether.
