2014-02-10
10:01 PM
2023-05-23
02:32 PM
Rubia Torres
2014-02-10 11:10 PM
2014-02-11 02:06 PM
Scott wrote:Would you use tilted flat roofs or just the pitched roof tool? Problem is one side has a nod in it...
I think that I would draw these roofs with the roof tool and use a composite structure. This way you should be able to make it clean up with your walls. I'm assuming you are using 17. Not sure if earlier versions can do this.
2014-02-11 08:44 PM
2014-02-11 10:20 PM
s2art wrote:An image as well as my archicad file and the sketchup of the project can be found here https://www.dropbox.com/sh/8njh2onlx5ql41m/D2FNnBwS7t
An image would help.
Also, add system information and AC version to your signature (in your profile, link at top of forum page) as answers may vary depending on what you are using.
2014-02-12 07:44 PM
2014-02-13 02:28 AM
2014-02-13 03:01 AM
2014-02-13 07:14 PM
