Roof wizard malfuntioning in Version 12
Can anyone confirm that the roof wizard is totally freaked out in version 12? I'm using freaked out because the whole thing is malfunctioning.
Thanks,
Please see this existing thread that already notes the bug (initial posts):
http://archicad-talk.graphisoft.com/viewtopic.php?t=26469
GS is working on the bug fix, but here is a workaround for now, assuming you have the 11 library available to you:
http://archicad-talk.graphisoft.com/viewtopic.php?p=134271#134271
Karl
Thanks Karl. I tried loading the V11 lib and roof maker lib in 12 but still wouldn't work. I ended up back saving the plan and opening in V11 and everything worked fine.
Thanks Again
