2004-05-20
05:56 PM
2023-05-26
12:37 PM
Rubia Torres
2004-05-21 12:16 AM
jkipfer wrote:You will have to open the part and save as a new part (Preferably in your custom office library). Add a new parameter "R" with the type set to angle. Then in the 3D script add "roty R" to the script. Without the quotes of course. Now you can match the the angle slope to that of your roof in the new parameter.
So from the other questions posted, I understand that you can't rotate in 3d. So then, how do I change the angle of a horizontal beam? For example, I want the start elevation to be 10' and the end elevation to be 12'. The library part I'm trying to perform this on is a purlin.
Thanks!
Jason
2004-05-21 03:12 PM
2004-05-21 03:44 PM
jkipfer wrote:Place the part that you want to modify in your current project. Select the object and then select File/GDL Objects/Open Object...
I see that some of the other library parts have an option for the rotation programmed in as you've said. How do I open and 'save as' a new part? Do I do this in the Library manager?
Thanks,
Jason
2004-05-21 07:35 PM
2004-05-21 09:02 PM
2004-05-22 05:59 AM
2004-05-23 02:29 AM
2004-05-24 06:34 PM
2004-05-25 01:31 AM
ashley wrote:ArchiCAD 7.0 does not have subtypes nor templates. They are new to 8.x.
Millard Brooking:
I open the window that you post and try to make it this morning, but somehow there is no "selec Subtype", " template", and " placeable"
Is it could be the reason that ArchiCAD 7.0 doesn't have this function?
