SEO
Hi All,
I am very new to archicad here. I wish to know, are there any tutorial about
SEO? It's pretty straight forward concept in archicad menu, but I can't seen to get it to work?
Please advise, Thank you.
BR
-N-
Have you looked in the reference manual? As I recall it's fairly clear on the subject. Once you get the palette open it is pretty straight forward. There may also be some more step by step instructions on the wiki.
Two important points:
1. After selecting the targets and hitting the "Get Target Elements" button make sure you deselect everything before selecting your operators, then the "Get Operators" button. (Can be done in reverse but make sure you deselect in between. Something cannot be a target AND an operator).
2. Do NOT delete your operators. They must remain in the model. You can turn their layer off, but if you delete them you lose their function.
Have fun.
