Display malfunction of Graphisoft ID dashboard
Learn more
Save a selection
Hello! Is there a way to save a selection as a new document?
3 Replies 3
Eduardo Rolon
Copy/Paste from one file to the other does not work?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Not in this case. ArchiCAD cannot copy/paste between commercial and educational programs. The only way would be if I duplicate the file and delete what I don't need in the second file but I also thought there might be an option to directly save the selection as a new file.
Eduardo Rolon
FYI, it is not possible to convert EDU to Commercial file nor it is permitted under the EDU license. If you open a EDU file in Commercial it will switch to EDU mode.
Another option to save selection is to select what you want and save as a module (.mod) then you can open this file and save-as a regular .pln
Though it will have the same problems as copy/paste between EDU and Commercial.
AC29 US/INT -> AC08
another Moderator
